Version 2.0.0.4977
Win10
Long time Plex user and have just come across Sonarr which looks brilliant so far.
Followed a couple of guides and have Sonarr kind of working. It finds series online no problem, it will add episodes to utorrent and start downloading fine. The downloads once completed are stored in the correct folder which is specified as a label in utorrent (I think).
Issue #1 Sonarr creates a new series folder in the Plex TV library however it doesn’t contain the date at the end in brackets. All my shows are labelled this way so Sonarr won’t detect existing episodes.
Issue #2 Once the download is finished in utorrent it goes to the correct torrents completed folder but doesn’t get transferred to the Plex TV library. Sonarr creates a series folder so permissions are ok but it doesn’t transfer. I followed the guide to stop utorrent seeding the file and Sonarr is running on the same server as Plex with admin privelages. Storage is on NAS.
Issue #3 When I restart Sonarr it loses control of utorrent. I have to go into it and test connection and then it works.
