Sonarr version (exact version): 3.0.3.895 Mono version (if Sonarr is not running on Windows): OS: win 10 latest Debug logs: provided upon request (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here. Post in .txt not .doc, .rtf or some other formatted document) Description of issue:
I gather from most of my posts, it is user error or not understanding how the app works completely despite considerable amount of reading/research. I am trying to answer my own questions, but these linger:
I keep running into two issues that make me scratch my head.
Please confirm: when I do a manual search, the results reflect what automatic search would use and in the order, it would be downloaded.
When I do a manual search, it searches by quality first as a first-order sort and clicking on a column to change the sort order actually changes the 2nd order search to that column instead of searching first order by that column. Is this by design or is this a bug? If it is by design, why? (use case: I want to sort by seeds, download the file with the most. It seems to be the most used use case, but I can not do this.)
If I have all my indexes are set to a minimum of 7 seeds, why am I getting results in a manual search that have less? I verified all my interactive is the same as automatic, and they all have 7 set at a minimum
4)custom filters seem to be broken. I tried setting a custom filter to only show results with minimum seeds of 10, but the results do not reflect this. Why?
I’m confused by your answer.
Interactive search results I thought I read shows the results as automatic uses. So the ones with less than the number of minimum seeds - are these then skipped?
The other question is why can’t I sort by seeds and get this list? It currently forces the upper cutoff limit to be the sort order. Why would anyone want that to be forced? (for example I often have shows that are only available in 720, but there are 1080 results with no seeds… I’m just trying to sort files that I can download - ones with seeds)
No, you can’t. The filters do not work. See screen shots below. V3 latest BTW. I tried filtering for seeds more than 11, but the results still contain all.
I’m stuck, and although I am reporting this, I keep getting that I’m wrong…?
When I try to sort by seeds, it does not sort properly. It sorts by resolution, then sorts by whatever column you click on.
This happens on android Chrome/Samsung browser, win 10 chrome, Firefox.
The screen shots with peers with the arrow shows the results I get when I click on it. I’m shocked to see your screen shot, it seems to be what I would expect. What sonarr version are you on, and what browser/system?
What show, and what filter? I checked again, and indeed it is filtering some, but not all.
I would like to check a show you are to see if it is just a specific download that happens to work
In just suggesting, by finding one with lots of results (popular) you will likely get my results… I have a ton of indexers, so I get tons of results anyway
