So I had to move some folders around to clean up my server.
Now I have an issue with an error. it says Missing root folder
I have tried to find the issue but cannot see what show is causing my problem.
Is there way to see this on the system some where?
Thanks inadvance
Just a few things to check/do and it should go away
- Check
Series Editor
for any series using the old path and correct them - Go to
Add Series
then chooseImport Existing
and remove any old root folders from there - Go to System: Tasks and run the
Health Check
task
