So basically, I have tried both SONARR and SICKRAGE tonight, trying to get them to work with HDBits and both of them are failing.
I logged into HDBITS.org, and I am using the passkey from my profile page.
I am getting an authentication error in both programs.
I have tried creating a new passkey as well. Twice.
When it fails trying to use the passkey, the next time that I log in to HDBITS it tells me that I have to now reset my password.
I also tried CURL, but with CURL I might be running into an SSL issue.
My log in SONARR shows :
Unable to connect to indexer: HDBits API request returned status code AuthFailed: Invalid authentication credentials
Exception
NzbDrone.Core.Indexers.Exceptions.IndexerException: HDBits API request returned status code AuthFailed: Invalid authentication credentials
at NzbDrone.Core.Indexers.HDBits.HDBitsParser.ParseResponse(IndexerResponse indexerResponse) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HDBits\HDBitsParser.cs:line 38
at NzbDrone.Core.Indexers.HttpIndexerBase1.FetchPage(IndexerRequest request, IParseIndexerResponse parser) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 286 at NzbDrone.Core.Indexers.HttpIndexerBase1.TestConnection() in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 311
In SICKRAGE (I know it doesn’t matter here but just in case)
2016-12-03 03:03:00 ERROR SEARCHQUEUE-MANUAL-80379 :: [HDBits] :: [a1bf3b3] Resulting JSON from provider isn’t correct, not parsing it
2016-12-03 03:03:00 WARNING SEARCHQUEUE-MANUAL-80379 :: [HDBits] :: Invalid username or password. Check your settings
I checked with HDBITS, they are saying my passkey and user combo is working fine for them doing a manual connection.
Did something change?
