Sonarr version (exact version): 2.0.0.5322
OS: Ubuntu 18.04 LTS (Docker)
Debug logs: https://pastebin.com/HUMAXGBB (sonar.debug.txt)
Description of issue: At import, files are copied instead of hardlinked
In my settings I have:
- Hardlinking enabled
- Completed Download Handling
- Enabled
- Remove disabled
Also in manual import the hardlink option is also missing:
This is my docker systemd script:
[Unit]
Description=Sonarr docker container
Requires=docker.service
After=docker.service
[Service]
Restart=always
RestartSec=30
ExecStart=/usr/bin/docker run --rm \
--name=sonarr \
-v /home/florens/sonarr/config/:/config \
-v /home/florens/plex/hdd1/:/library \
-e PGID=1005 -e PUID=1000 \
-e TZ='Europe/Brussels' \
--network host \
linuxserver/sonarr
ExecStop=/usr/bin/docker stop sonarr
[Install]
WantedBy=multi-user.target
The /library folder has 2 subfolders: downloads and tv so these two are in the same volume.
The gid is my account florens, the gid is media which I use for everything that needs access to the library and downloads folders. I have the same issue when gid is 1000.
florens@flops-server:~$ id florens
uid=1000(florens) gid=1000(florens) groups=1000(florens),4(adm),24(cdrom),27(sudo),30(dip),46(plugdev),108(lxd),119(deluge),1005(media)
I tried manually linking a file in a shell in the docker container and that works.
sudo docker exec -i -t sonarr /bin/bash
root@flops-server:/# ls
app boot defaults docker-mods etc init lib64 library mnt proc run srv tmp usr
bin config dev downloads home lib libexec media opt root sbin sys tv var
root@flops-server:/# rm -rf tv
rm: cannot remove 'tv': Device or resource busy
root@flops-server:/library# ln downloads/Rick.and.Morty.S02.1080p.BluRay.x264-YELLOWBiRD\[rartv\]/Rick.and.Morty.S02E02.1080p.BluRay.x264-YELLOWBiRD.mkv tv/Rick\ and\ Morty/rickandmortytest.mkv
I did notice here that the downloads and tv folders on the root still exist and are unremovable.
An example of a download after import:
florens@flops-server:~/plex/hdd1/downloads/The.Walking.Dead.S09E16.WEB.h264-TBS[rarbg]$ stat the.walking.dead.s09e16.web.h264-tbs.mkv
File: the.walking.dead.s09e16.web.h264-tbs.mkv
Size: 526981753 Blocks: 1029272 IO Block: 4096 regular file
Device: 801h/2049d Inode: 81526881 Links: 1
Access: (0664/-rw-rw-r--) Uid: ( 115/ deluge) Gid: ( 119/ deluge)
Access: 2019-05-13 11:38:56.119112029 +0200
Modify: 2019-05-13 11:38:21.925800183 +0200
Change: 2019-05-13 11:38:21.925800183 +0200
Birth: -
If it’s any help, I have the same issue with Radarr.
Any help is appreciated. If you need more information, please ask.
