The file I tested with: Stargirl.S01E03.WEBRip.x264-ION10
Transmission is set to seed until 0.01 ratio or 1 minute idle as a test. I can confirm that it shows status “Finished”.
As I can tell from the Sonarr logs, it appears that “isFinished”:false which I guess is causing the file not to copy to the final destination and delete once completed with seeding?
My understanding of the issue was it wasn’t importing at all, but the logs indicated it imported, is the issue it didn’t hardlink for the import? If so, I’ll need to see the logs of the actual import (and the docker volume mapping for the Sonarr container), if not then I’m not sure because according to Sonarr it did import the file.
