Sonarr version 3.0.9.1549:
Mono version 6.12.0.182:
OS: Docker on Synology
Sonarr seems to be replacing any h.264 encoded file with an h.265 file even though the h.265 file is significantly smaller. For example, it has just replaced Motherland.Fort.Salem.S03E10.1080p.WEB.h264-GOSSIP which was 2.3GB with Motherland.Fort.Salem.S03E10.1080p.HEVC.x265-MeGusta which is just 431MB. I know h.265 is more efficient but, bearing in mind I have no idea what I’m talking about, I struggle to believe the smaller file is better quality.
I can’t see anything in my settings that would trigger this behaviour. My quality profile is set up like this:
I’ll turn on debugging if the logs are required but I suspect this is a user issue so any pointers as to how I can stop it will be gratefully received.
Thanks.
