I am running Sonarr on my NAS Synology and when I look at the Sonarr log, I see a lot of errors from Owin and also global exception handler.
This is the error
/volume1/@appstore/nzbdrone/share/NzbDrone/Microsoft.AspNet.SignalR.Core.dll Error : 0 : SignalR exception thrown by Task: System.AggregateException: One or more errors occurred —> System.IO.IOException: Write failure —> System.ObjectDisposedException: The object was used after being disposed.
at System.Net.Sockets.Socket.Send (System.Byte[] buf, Int32 offset, Int32 size, SocketFlags flags) [0x00000] in :0
at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in :0
at System.Net.ResponseStream.InternalWrite (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in :0
at System.Net.ResponseStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in :0
at Microsoft.Owin.Host.HttpListener.RequestProcessing.ExceptionFilterStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in :0
–> (Inner exception 0) System.IO.IOException: Write failure —> System.ObjectDisposedException: The object was used after being disposed.
This is the fatal error (global exception handler 1)
System.DllNotFoundException: libgdiplus.so
at (wrapper managed-to-native) System.Drawing.GDIPlus:GdiplusStartup (ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus…cctor () [0x00000] in :0
This is the fatal error (global exception handler 2)
System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.GDIPlus —> System.DllNotFoundException: libgdiplus.so
at System.Drawing.Image.InitFromStream (System.IO.Stream stream) [0x00000] in :0
at System.Drawing.Bitmap…ctor (System.IO.Stream stream, Boolean useIcm) [0x00000] in :0
at (wrapper remoting-invoke-with-check) System.Drawing.Bitmap:.ctor (System.IO.Stream,bool)
at ImageResizer.ImageBuilder.DecodeStream (System.IO.Stream s, ImageResizer.ResizeSettings settings, System.String optionalPath) [0x00000] in :0
at ImageResizer.ImageBuilder.LoadImage (System.Object source, ImageResizer.ResizeSettings settings, Boolean restoreStreamPos) [0x00000] in :0
Any idea how to fix this? Thanks in advance.
