Trying to switch over from SickRage to sonarr. I installed it using the Atomic-Toolkit, opened it up and did all the initial configurations and then started adding my series. It would crash the backend, and I would have to manually restart it. The debug log had this for the entry:
Message EPIC FAIL: Object reference not set to an instance of an object: Object reference not set to an instance of an object
Exception System.NullReferenceException: Object reference not set to an instance of an object at System.Threading.Timer+Scheduler.SchedulerThread () [0x00000] in <filename unknown>:0 at System.Threading.Thread.StartInternal () [0x00000] in <filename unknown>:0
Any suggestions on what I need to do?
OS: Ubuntu 14.04.3 LTS (headless server)
Thank you
