Sonarr version (exact version): 2.0.0.5054 - 04 Nov 2017 Mono version (if Sonarr is not running on Windows): OS: MacOS High Sierra Version 10.13.1 ((Debug logs)): 4 (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here) Description of issue:
I’m really new to adding torrents/index and having dificulties adding new indexers, at the moment i only have Rarbg.
Recently i made an account on nzbplanet, got the API key from my Profile page (i’m not a VIP) enter all the dates in Sonarr … and from here i got stuck. When i hit test i get test failed …
I also try to generate a new API on nzbplanet but that didnt work eighter
personally the free ones aren’t that great and have often issues.
so i don’t use them anymore.
they often got timed out in Sonarr.
So if you want a reliable indexer you will need to pay for it.
You could check reddit for links to free ones if you want to give it a try.
My personal favorites are ones that have closed invites at the moments or no invites at al.
Without naming them,
check in Sonarr under usenet indexers and check the presets under newsnab.
My favorite isn’t in the list,
but you could try nr’s 3,6 and 11
