Sonarr version (exact version): 2.0.0.5322
Mono version (if Sonarr is not running on Windows): 5.18.1.0
OS: ubuntu 16.04
Hi,
I’ve been trying to download a foreign show called “Chyłka” (Polish), but it’s being rejected due to it being an ‘Unknown series’. I’m able to search for the show manually and can see the results provided by the indexer.
The show’s TVDB ID: 353873
I have tried searching with the default HD - 720p/1080p quality preset as well as creating my own with the same settings as the default one with the only difference being the language, which is set to Polish. This didn’t work either.
I have already filled out the online Naming Exception form. I can see the entry in the spreadsheet; does this mean that it’s still being processed or the exception has been added?
I would appreciate suggestions or help.
Thanks
