First Time Setup Guide
Hello Everyone,
I could use some more help. I wanted to try setting Sonarr on my media computer which has Plex and Qbittorant on it. My trouble is finding a quide or a video on how to do it because everything I google is either out of date or years old.
I find this program instersting as rigth now its takes me a while to look at all the torrents and see what shows I am missing.
Only thing I can of is I do a file server , so on my media computer that drives are networked mapped.
Thanks for the help and time.
Trash Guides (which also links to the Wiki where appropriate) should get you sorted. Home - TRaSH Guides
Thanks @markus101 but there guides are for when you have everything installed. I need a guide at starts at step 1 and how to set everything up.
Everything I have found is like I said really dated.
The very first line and link from the Trash Guides page:
Basic guides
For Installation, Quick Start Guide, and the basics of Sonarr, please check the official WikiArr.
Install it. Then follow the guides to configure it.
Reference: https://trash-guides.info/File-and-Folder-Structure/How-to-set-up/
That’s as guided as you’re going to get from official or recommended sources.
If you try and something isn’t working, you can come back and ask for specific help. But the basics to get up and running are already all laid out for you.
