OS: Windows 10
Debug logs: 2023-06-16 14:45:43.2|Debug|Api|[PUT] /api/v3/config/host: 202.Accepted (26 ms)
2023-06-16 14:45:43.2|Debug|Api|[GET] /api/v3/health: 200.OK (0 ms)
2023-06-16 14:45:43.5|Debug|Api|[GET] /api/v3/health: 200.OK (0 ms)
2023-06-16 14:45:51.2|Debug|Api|[GET] /api/v3/queue/details?seriesId=232: 200.OK (2 ms)
2023-06-16 14:45:51.2|Debug|Api|[GET] /api/v3/episode?seriesId=232: 200.OK (3 ms)
2023-06-16 14:45:51.2|Debug|Api|[GET] /api/v3/episodeFile?seriesId=232: 200.OK (3 ms)
2023-06-16 14:45:54.1|Debug|IndexerFactory|Temporarily ignoring indexer Rarbg till 6/17/2023 6:10:14 AM due to recent failures.
2023-06-16 14:45:54.1|Debug|IndexerFactory|Temporarily ignoring indexer Zooqle till 6/17/2023 11:35:51 AM due to recent failures.
2023-06-16 14:45:54.1|Info|ReleaseSearchService|Searching indexers for [The Idol (2023) : S01E01]. 5 active indexers
2023-06-16 14:45:54.1|Debug|NewznabRequestGenerator|Indexer capabilities lacking season & ep query parameters, no Standard series search possible.
2023-06-16 14:45:54.1|Debug|Torznab|Downloading Feed http://127.0.0.1:9117/api/v2.0/indexers/thepiratebay/results/torznab/api?t=tvsearch&cat=5000,5040,100208&extended=1&apikey=(removed)&offset=0&limit=100&q=Idol%202023&season=1&ep=1
2023-06-16 14:45:54.1|Debug|Torznab|Downloading Feed http://127.0.0.1:9117/api/v2.0/indexers/iptorrents/results/torznab/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100&imdbid=tt14954666&season=1&ep=1
2023-06-16 14:45:54.1|Debug|Torznab|Downloading Feed http://127.0.0.1:9117/api/v2.0/indexers/1337x/results/torznab/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100&q=The%20Idol%20(2023)&season=1&ep=1
2023-06-16 14:45:54.1|Debug|Torznab|Downloading Feed http://127.0.0.1:9117/api/v2.0/indexers/eztv/results/torznab/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100&q=Idol%202023&season=1&ep=1
2023-06-16 14:45:54.1|Debug|Torznab|Downloading Feed http://127.0.0.1:9117/api/v2.0/indexers/iptorrents/results/torznab/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100&q=Idol%202023&season=1&ep=1
2023-06-16 14:45:56.1|Debug|ReleaseSearchService|Total of 0 reports were found for [The Idol (2023) : S01E01] from 5 indexers
2023-06-16 14:45:56.1|Debug|ReleaseSearchService|Setting last search time to: 6/16/2023 7:45:56 PM
2023-06-16 14:45:56.1|Info|DownloadDecisionMaker|No results found
Description of issue: Never had an issue with any previous shows and can still search and find new shows I add. Recently tried adding ‘The Idol (2023)’ and am encountering no results through automatic and manual searching but can easily see lots of results when I go searching outside of Sonarr
