Filter DV prevents other series from being downloaded
Hi guys, I would like to do the following with Sonarr.
I want Sonarr to download my series on its own. Here I have created 1080p/2160p filters.
Now it is important to me that DV is preferred or DV.HDR is loaded.
Currently, it seems that when I create DV filters, it no longer loads 1080p series.
I used this regex Code at release filter: /\b(dv|dovi|dolby[ .]?vision)\b/i
Could this be a solution?
In the respective series, I specify under tag that I prefer dv to uhd.
Then I can save myself the general filter.
greetz buendl
Sounds like you are on the right track to fix your issue. You may also have your release profile setup suboptimally
https://wiki.servarr.com/sonarr/settings#release-profiles
You’ll likely want your dv stuff as preferred vs must contain. Or as you mentioned, use a tag to only apply it to 4k series.
Thanks for the confirmation, I will test whether this is a sensible approach.
That’s the question: did the regex reject the other downloads or prefer/must contain 100?
Thats why i use a 2nd Sonarr. Actualy 3. 1 for DV, 1 for 1080, and 1 for 4k non DV.
