OS: Windoes 10
Debug logs: none
Description of issue: Custom created filter. When I select the TV Show at the right hand side you can go to next or go to previous Show. But this action does not take in account the selected filter and moves next / previous in the “select all filter”. Only way to select the show is back to overall view, select next/previous.
This seems to be by design. The same occurs for me.
The Filtered view is applied to the top level view of your library.
Once you click on a show, you are taken out of this filtered view and just into the entry for that show.
The Next Previous is applied at the show level and is just navigating through your entire library. From 1 to 2 to 3 etc. It has no knowledge or relation to how you got to that show listing.
You could submit a Feature Request for what you’re asking.
This is correct, it is by design, the filtered list only exists while it is displayed, once you navigate to the details page that sorted list is no longer applied.
