i have found that the renamer does not recognise the SAB default file names, I always have to rename them manually to match the required format, is there something wrong with the set-up.
Not sure if this has anything to do with the other thread, but I suspect it doesn’t.
Please explain the issue more thoroughly as its not clear what the issues is.
SAB renaming should be disabled.
