Sonarr version (exact version): forked the latest develop branch (I’m building as a contributor)
OS: Debian GNU/Linux 12 (bookworm). I’m specifically using Github Codespaces.
I’m following the contributor build instructions on this wiki page (the “Command line” section) :
https://wiki.servarr.com/en/sonarr/contributing
I start the frontend:
yarn install
yarn start
I start the backend (using commandline not Visual Studio):
dotnet clean src/Sonarr.sln -c Debug
dotnet msbuild -restore src/Sonarr.sln -p:Configuration=Debug -p:Platform=Posix -t:PublishAllRids
I run the following file:
./_output/net6.0/linux_x86/publish/Sonarr
This file does seem to start the backend server, but I see the following error in the Terminal:
[Error] BrowserService: Couldn't open default browser to http://localhost:8989
[v10.0.0.2957] System.ComponentModel.Win32Exception (2): An error occurred trying to start process 'http://localhost:8989' with working directory '/workspaces/Sonarr/_output/net6.0/linux-x64/publish'. No such file or directory
at System.Diagnostics.Process.ForkAndExecProcess(ProcessStartInfo startInfo, String resolvedFilename, String[] argv, String[] envp, String cwd, Boolean setCredentials, UInt32 userId, UInt32 groupId, UInt32[] groups, Int32& stdinFd, Int32& stdoutFd, Int32& stderrFd, Boolean usesTerminal, Boolean throwOnNoExec)
at System.Diagnostics.Process.StartCore(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at NzbDrone.Common.Processes.ProcessProvider.OpenDefaultBrowser(String url) in ./Sonarr.Common/Processes/ProcessProvider.cs:line 105
at NzbDrone.Host.BrowserService.LaunchWebUI() in ./Sonarr.Host/BrowserService.cs:line 37
When I go to localhost:8989, I get the following error message:
"type": "https://tools.ietf.org/html/rfc7231#section-6.5.4",
"title": "Not Found",
"status": 404,
"traceId": "00-8d2326d161fb8cee537aeee14fe6c210-b021ee4f59675154-00"
Thank you for your help.
