Sonarr version (exact version): 0.2.0.1504
Mono version (if Sonarr is not running on Windows): 5.8.0.108
OS: DSM 6
Request Failed. PUT /api/config/mediamanagement: Exception has been thrown by the target of an invocation.
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Data.SQLite.SQLiteException: constraint failed
UNIQUE constraint failed: Config.Key
at System.Data.SQLite.SQLite3.Reset (System.Data.SQLite.SQLiteStatement stmt) [0x00083] in <61a20cde294d4a3eb43b9d9f6284613b>:0
at System.Data.SQLite.SQLite3.Step (System.Data.SQLite.SQLiteStatement stmt) [0x0003c] in <61a20cde294d4a3eb43b9d9f6284613b>:0
at System.Data.SQLite.SQLiteDataReader.NextResult () [0x0016b] in <61a20cde294d4a3eb43b9d9f6284613b>:0
at System.Data.SQLite.SQLiteDataReader…ctor (System.Data.SQLite.SQLiteCommand cmd, System.Data.CommandBehavior behave) [0x00090] in <61a20cde294d4a3eb43b9d9f6284613b>:0
at (wrapper remoting-invoke-with-check) System.Data.SQLite.SQLiteDataReader…ctor(System.Data.SQLite.SQLiteCommand,System.Data.CommandBehavior)
at System.Data.SQLite.SQLiteCommand.ExecuteReader (System.Data.CommandBehavior behavior) [0x0000c] in <61a20cde294d4a3eb43b9d9f6284613b>:0
at System.Data.SQLite.SQLiteCommand.ExecuteScalar (System.Data.CommandBehavior behavior) [0x00006] in <61a20cde294d4a3eb43b9d9f6284613b>:0
at System.Data.SQLite.SQLiteCommand.ExecuteScalar () [0x00006] in <61a20cde294d4a3eb43b9d9f6284613b>:0
at Marr.Data.QGen.InsertQueryBuilder1[T].Execute () [0x00046] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\Marr.Data\QGen\InsertQueryBuilder.cs:140 at Marr.Data.DataMapper.Insert[T] (T entity) [0x0005d] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\Marr.Data\DataMapper.cs:728 at NzbDrone.Core.Datastore.BasicRepository
1[TModel].Insert (TModel model) [0x0002d] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Datastore\BasicRepository.cs:111
at NzbDrone.Core.Configuration.ConfigRepository.Upsert (System.String key, System.String value) [0x0000b] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Configuration\ConfigRepository.cs:33
at NzbDrone.Core.Configuration.ConfigService.SetValue (System.String key, System.String value) [0x0001a] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Configuration\ConfigService.cs:399
at NzbDrone.Core.Configuration.ConfigService.GetValue (System.String key, System.Object defaultValue, System.Boolean persist) [0x0009a] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Configuration\ConfigService.cs:373
at NzbDrone.Core.Configuration.ConfigService.get_RijndaelPassphrase () [0x00000] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Configuration\ConfigService.cs:311
at (wrapper delegate-invoke) .invoke_callvirt_string_ConfigService(NzbDrone.Core.Configuration.ConfigService)
at System.Reflection.MonoProperty.GetterAdapterFrame[T,R] (System.Reflection.MonoProperty+Getter2[T,R] getter, System.Object obj) [0x00000] in /spksrc/native/mono/work-native/mono-5.8.0.108/mcs/class/corlib/System.Reflection/MonoProperty.cs:329 at System.Reflection.MonoProperty.GetValue (System.Object obj, System.Object[] index) [0x0005f] in /spksrc/native/mono/work-native/mono-5.8.0.108/mcs/class/corlib/System.Reflection/MonoProperty.cs:390 --- End of inner exception stack trace --- at System.Reflection.MonoProperty.GetValue (System.Object obj, System.Object[] index) [0x0006e] in /spksrc/native/mono/work-native/mono-5.8.0.108/mcs/class/corlib/System.Reflection/MonoProperty.cs:392 at NzbDrone.Core.Configuration.ConfigService.AllWithDefaults () [0x0001f] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Configuration\ConfigService.cs:44 at NzbDrone.Core.Configuration.ConfigService.SaveConfigDictionary (System.Collections.Generic.Dictionary
2[TKey,TValue] configValues) [0x00000] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Configuration\ConfigService.cs:53
at NzbDrone.Api.Config.NzbDroneConfigModule1[TResource].SaveConfig (TResource resource) [0x00055] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Api\Config\NzbDroneConfigModule.cs:48 at NzbDrone.Api.REST.RestModule
1[TResource].<set_UpdateResource>b__44_0 (System.Object options) [0x00008] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Api\REST\RestModule.cs:171
at (wrapper dynamic-method) System.Object.CallSite.Target(System.Runtime.CompilerServices.Closure,System.Runtime.CompilerServices.CallSite,System.Func`2<object, object>,object)
at Nancy.Routing.Route+<>c__DisplayClass4.b__3 (System.Object parameters, System.Threading.CancellationToken context) [0x00049] in <63c44d6f8d7e4f339a987bf9eb94d931>:0
Description of issue: The whole Folder structure and copying of the files does not work. (Radarr work perfectly fine though)
Any ideas where the issue comes from ?
