Howdy,
I just noticed that I’ve been getting a ton of errors related to nzbgeek. I don’t recall ever seeing this before migrating over to Ubuntu, nor is it happening with any other indexer. Is this something I should inform nzbgeek about?
Thanks!
An error occurred while processing feed. https://censored.info/api?t=tvsearch&cat=5030,5040&extended=1&apikey=<removed>: unexpected end of file in an attribute value Line 2715, position 142. System.Xml.XmlException: unexpected end of file in an attribute value Line 2715, position 142. at Mono.Xml2.XmlTextReader.ReadAttributeValueTokens (Int32 dummyQuoteChar) [0x00000] in <filename unknown>:0 at Mono.Xml2.XmlTextReader.ReadAttributes (Boolean isXmlDecl) [0x00000] in <filename unknown>:0 at Mono.Xml2.XmlTextReader.ReadStartTag () [0x00000] in <filename unknown>:0 at Mono.Xml2.XmlTextReader.ReadContent () [0x00000] in <filename unknown>:0 at Mono.Xml2.XmlTextReader.Read () [0x00000] in <filename unknown>:0 at System.Xml.XmlTextReader.Read () [0x00000] in <filename unknown>:0 at Mono.Xml.XmlFilterReader.Read () [0x00000] in <filename unknown>:0 at Mono.Xml.XmlFilterReader.Read () [0x00000] in <filename unknown>:0 at System.Xml.XmlReader.ReadEndElement () [0x00000] in <filename unknown>:0 at System.Xml.Linq.XElement.LoadCore (System.Xml.XmlReader r, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XNode.ReadFrom (System.Xml.XmlReader r, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XContainer.ReadContentFrom (System.Xml.XmlReader reader, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XElement.LoadCore (System.Xml.XmlReader r, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XNode.ReadFrom (System.Xml.XmlReader r, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XContainer.ReadContentFrom (System.Xml.XmlReader reader, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XElement.LoadCore (System.Xml.XmlReader r, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XNode.ReadFrom (System.Xml.XmlReader r, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XContainer.ReadContentFrom (System.Xml.XmlReader reader, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XElement.LoadCore (System.Xml.XmlReader r, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XNode.ReadFrom (System.Xml.XmlReader r, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XContainer.ReadContentFrom (System.Xml.XmlReader reader, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XDocument.ReadContent (System.Xml.XmlReader reader, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XDocument.LoadCore (System.Xml.XmlReader reader, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XDocument.Load (System.IO.TextReader textReader, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XDocument.Parse (System.String text, LoadOptions options) [0x00000] in <filename unknown>:0 at System.Xml.Linq.XDocument.Parse (System.String text) [0x00000] in <filename unknown>:0 at NzbDrone.Core.Indexers.Newznab.NewznabPreProcessor.Process (System.String source, System.String url) [0x00000] in <filename unknown>:0 at NzbDrone.Core.Indexers.Newznab.NewznabParser.PreProcess (System.String source, System.String url) [0x00000] in <filename unknown>:0 at NzbDrone.Core.Indexers.RssParserBase.Process (System.String xml, System.String url) [0x00000] in <filename unknown>:0 at NzbDrone.Core.Indexers.Newznab.NewznabParser.Process (System.String xml, System.String url) [0x00000] in <filename unknown>:0 at NzbDrone.Core.Indexers.FetchFeedService.Fetch (IIndexer indexer, IEnumerable1 urls) [0x00000] in :0 `
