Feature Similar to SickBeard's Manual Post Processing?
Hi guys, sometimes when I have trouble with Usenet I like to download a series manually with Torrents.
How would I go about doing this? Assigning the factory folder to my Torrent downloads directory?
Thanks
Use the drone factory, set it up and drop the files/folders in there.
Hi Markus, I did that but nzbdrone doesn’t seem to be doing anything.
The series was already added to drone? Does the series title in the filename/folder match the title in drone?
Logs should show whats going on, but you may need to enable [debug logging] (https://github.com/NzbDrone/NzbDrone/wiki/Log-Files) to see exactly whats going on.
Thanks, that worked.
