What is your retry interval? Also, your log has been removed, so we’re lacking quite some info here. The red blocks in the screenshot make perfect sense: the download that you sent to SAB at 10:42 failed at 10:46 according to the emails you say you received and NzbDrone picked this up at 10:47…
Keep in mind that this failed download handling only handles failing reports, so NZB files. It does not handle the same releases as far as I’m aware, and to be honest I wouldn’t want it to. Just because Defiance.S02E09.720p.HDTV.x264-IMMERSE fails when it’s posted to one group doesn’t mean it would fail when posted to another.
How is the episode marked in your episode list? I doubt Drone would keep adding it if it was already marked as successful there.
The WEB-DL was successfully completed on 17th August.
This is the Activity for this ep:
if you over over the ‘i’ they all say the same:
If I do a manual search I see this:
All of the red symbols say:
Now I dont have drone set to remove failed downloads from SAB, so not sure if that is doing something crazy, just seems odd that it would do this for more than a week
and it successfully getting the new ID from SAB: 14-8-28 01:00:07.9|Debug|FailedDownloadService|[New_Tricks.11x02.Tender_Loving_Care.720p_HDTV_x264-FoV] Changed id from 1-SABnzbd_nzo_cwjkvq to 1-SABnzbd_nzo_szucse.
Yes there are from previous days like the image from a few posts up shows - I dont have the logs now, but I remember they say the same thing… usually it twice each day.
Yes, it is initiated after an auto-update. (hench my earlier question about restarts)
We only keep track of the retry count in memory, not in the database. This means of drone restarts during a ‘wait for retry’ period, it essentially resets the counter. That isn’t bad, coz we have plenty of hours per day that we don’t push new versions. Would only cause a few more retries at the most.
The problem was that we didn’t check the history to see if we marked the download failed, at least, not until after the retry logic was evaluated.
The reason why not more people are running into it is because they have ‘Remove’ enabled, so after finishing the retry sequence the sab history item gets removed by drone.
aha, yes, I didn’t consider auto updates into the equation…
Superb work! Yourself and Markus… It was obvious from when I first started using Drone a few months ago what it can become, so I did donate a small amount after just using it for a few days!
