Sonarr version (exact version): 2.0.0.4326
Mono version (if Sonarr is not running on Windows): 3.10.0 (mono-3.10.0-branch/ce003f4 Tue Nov 25 20:18:29 UTC 2014)
OS: Raspian (Linux raspberrypi 4.4.26+ #915 Thu Oct 20 17:02:14 BST 2016 armv6l GNU/Linux)
((Debug logs)): http://pastebin.com/yZ4MXDZR (sonarr.txt log) & http://pastebin.com/Cm2G9y58 (sonarr.debug.txt)
The NNTP server I am using isn’t that quick so I have a SABnzbd propagation delay set to ensure my downloads complete OK. Found in SABnzbd (Using v1.1.1RC2, is in 1.1.0 and above) found in Config, Switches, Queue.
When that is set, Sonarr reports errors in the logs due to that, this is just cosmetic it seems, but I thought it was worth mentioning. It almost looks like Sonarr doesn’t know how to interpret “Propagating” when it queries SABnzbd for the queue status. It happens every minute and stops when the Sabnzbd item’s propagation timer has reached zero and the queue is back to normal.
