Sonarr version (exact version): Main 3.0.10.1567 (Linux)
Mono version (if Sonarr is not running on Windows): Mono JIT compiler version 6.8.0.105 (Debian 6.8.0.105+dfsg-3.2 Mon Jul 12 07:04:24 UTC 2021)
OS: Raspbian GNU/Linux 11 (bullseye)
Native Crash Reporting
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Native stacktrace:
(No frames)
Telemetry Dumper:
Pkilling 0x74723440 from 0x76faa240
Entering thread summarizer pause from 0x76faa240
Finished thread summarizer pause from 0x76faa240.
Waiting for dumping threads to resume
External Debugger Dump:
[New LWP 27384]
[New LWP 27385]
[Thread debugging using libthread_db enabled]
Using host libthread_db library “/lib/arm-linux-gnueabihf/libthread_db.so.1”.
Dwarf Error: Could not find abbrev number 121 in CU at offset 0x0 [in module /usr/lib/mono/aot-cache/arm/mscorlib.dll.so]
0x76dac034 in __GI___wait4 (pid=27388, stat_loc=0x7ebc5fb0, options=0, usage=0x0) at …/sysdeps/unix/sysv/linux/wait4.c:27
27 …/sysdeps/unix/sysv/linux/wait4.c: No such file or directory.
Id Target Id Frame
- 1 Thread 0x76faa240 (LWP 27383) “mono” 0x76dac034 in __GI___wait4 (pid=27388, stat_loc=0x7ebc5fb0, options=0, usage=0x0) at …/sysdeps/unix/sysv/linux/wait4.c:27
2 Thread 0x763ff440 (LWP 27384) “SGen worker” futex_wait_cancelable (private=0, expected=0, futex_word=0x447698) at …/sysdeps/nptl/futex-internal.h:186
3 Thread 0x74723440 (LWP 27385) “Finalizer” futex_abstimed_wait_cancelable (private=0, abstime=0x0, clockid=0, expected=1, futex_word=0x43f73c) at …/sysdeps/nptl/futex-internal.h:323
Thread 3 (Thread 0x74723440 (LWP 27385) “Finalizer”):
#0 futex_abstimed_wait_cancelable (private=0, abstime=0x0, clockid=0, expected=1, futex_word=0x43f73c) at …/sysdeps/nptl/futex-internal.h:323
#1 do_futex_wait (sem=sem@entry=0x43f73c, abstime=0x0, clockid=0) at sem_waitcommon.c:117
#2 0x76e9bc90 in __new_sem_wait_slow (sem=0x43f73c, abstime=0x0, clockid=0) at sem_waitcommon.c:285
#3 0x002c2120 in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 2 (Thread 0x763ff440 (LWP 27384) “SGen worker”):
#0 futex_wait_cancelable (private=0, expected=0, futex_word=0x447698) at …/sysdeps/nptl/futex-internal.h:186
#1 __pthread_cond_wait_common (abstime=0x0, clockid=0, mutex=0x0, cond=0x447670) at pthread_cond_wait.c:508
#2 __pthread_cond_wait (cond=0x447670, mutex=0x0) at pthread_cond_wait.c:638
#3 0x00327c84 in ?? ()
Thread 1 (Thread 0x76faa240 (LWP 27383) “mono”):
#0 0x76dac034 in __GI___wait4 (pid=27388, stat_loc=0x7ebc5fb0, options=0, usage=0x0) at …/sysdeps/unix/sysv/linux/wait4.c:27
#1 0x0009f73c in ?? ()
[Inferior 1 (process 27383) detached]
Basic Fault Address Reporting
Memory around native instruction pointer (0x76e995c0):0x76e995b0 bc ff ff ea 98 70 00 00 f0 4f 2d e9 14 d0 4d e2 …p…O-…M.
0x76e995c0 24 50 90 e5 a5 31 b0 e1 28 01 00 0a 00 c0 a0 e1 $P…1…(…
0x76e995d0 01 50 15 e2 20 30 bc e5 00 e0 a0 e1 80 50 a0 13 .P… 0…P…
0x76e995e0 0a 00 00 ea 01 10 83 e3 9f 2f 9c e1 03 00 52 e1 …/…R.
Managed Stacktrace:
at <unknown> <0xffffffff>
at System.Globalization.CompareInfo:get_UseManagedCollation <0x00057>
at System.Globalization.CompareInfo:CreateSortKeyCore <0x00017>
at System.Globalization.CompareInfo:CreateSortKey <0x00047>
at System.Globalization.CompareInfo:GetSortKey <0x0004b>
at System.Globalization.CompareInfo:GetHashCodeOfStringCore <0x00033>
at System.Globalization.CompareInfo:GetHashCodeOfString <0x0008f>
at System.CultureAwareComparer:GetHashCode <0x0003f>
at System.StringComparer:GetHashCode <0x0007f>
at System.Collections.Hashtable:GetHash <0x0005b>
at System.Collections.Hashtable:InitHash <0x0003f>
at System.Collections.Hashtable:get_Item <0x0007f>
at System.Collections.Specialized.NameObjectCollectionBase:FindEntry <0x00047>
at System.Collections.Specialized.NameObjectCollectionBase:BaseGet <0x0001b>
at System.Collections.Specialized.NameValueCollection:Get <0x0001b>
at System.Collections.Specialized.NameValueCollection:get_Item <0x0002b>
at NLog.Common.InternalLogger:GetAppSettings <0x00027>
at NLog.Common.InternalLogger:GetSettingString <0x0002b>
at NLog.Common.InternalLogger:GetSetting <0x0002b>
at NLog.Common.InternalLogger:Reset <0x0001f>
at NLog.Common.InternalLogger:.cctor <0x00037>
at System.Object:runtime_invoke_void <0x0007b>
at NLog.Config.LoggingConfiguration:Dump <0x00053>
at NLog.LogFactory:set_Configuration <0x001bb>
at NLog.LogManager:set_Configuration <0x0002b>
at NzbDrone.Common.Instrumentation.NzbDroneLogger:.cctor <0x00027>
at NzbDrone.Console.ConsoleApp:.cctor <0x00013>
Aborted
Description of issue: Crash when launching Sonarr
