I’m very new to this. I’m trying to add transmission to Sonarr and wonder what to write instead of localhost. I see under properties -> Network -> Peer listening port, which is the port i need to write.
How can i fiks this error: Unknown exception: Error getting response stream (ReadDone2): ReceiveFailure
Use localhost is Transmission and Sonarr are on the same system, otherwise use the IP of the remote system. The port is for the Transmission HTTP API, the default should be populated.
