Sonarr version (exact version): [v3.0.3.713]
OS: Windows 10
Debug logs: https://www.dropbox.com/s/qv9k58hxc5akllr/20200305_sonarr.debug.0.txt?dl=0
If I search manually in Jackett itself, there are more results.
I want Sonarr to find these through the indexer as well, but it looks like I am not able to figure out how.
What can I change in the settings to achieve this?
a lot of these wanted results don’t popup through the indexer:
These are the result of Category: 5000 & 5040
And they are not showing up in the logs as a possible result.
Also when I manually do a search through Sonarr, these links are missing.
My idea is that a file that is called like “The.Walking.Dead.S10E09” with this interpunction does get found and if there are spaces they don’t get found.
20200305,16:59,edit; I created a new machine with Jackett and configured it with only 1337x.to and Toros.
And this time it showed the missing reports.
But it was queried differently by Sonarr and then the results are different.
I noticed that 1337x.to and Toros don’t show results on a imdbid-query:
20-3-5 10:43:57.9|Debug|Torznab|Downloading Feed http://127.0.0.1:9117/torznab/all/api?t=tvsearch&cat=5000,5010,5020,5040&extended=1&apikey=(removed)&offset=0&limit=1000&imdbid=tt1520211&season=10&ep=9
The working query:
20-3-5 16:26:25.7|Debug|Torznab|Downloading Feed http://192.168.1.84:9117/torznab/all/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=1000&q=Walking%20Dead&season=10&ep=9
20-3-5 16:26:26.3|Debug|NzbSearchService|Total of 67 reports were found for [The Walking Dead : S10E09] from 1 indexers
20-3-5 16:26:26.3|Debug|NzbSearchService|Setting last search time to: 5-3-2020 15:26:26
20-3-5 16:26:26.3|Info|DownloadDecisionMaker|Processing 67 releases
I should have 2 indexers and put in the Series which Indexer to use or something like that.
Because once you know which trackers cannot work with tvdbid’s or imdbid’s then we ge a better endresult.
Kind regards,
Marcel
