Episodes missing from disk - Sonarr not grabbing them automatically
Mono version (if Sonarr is not running on Windows): 5.12.0.226
OS: DSM6
Sonarr has been working perfectly but recently some shows don’t download and are flagged as ‘missing from disk’. If I click manual search they are immediately found. Is Sonarr checking too soon? Any way to adjust this?
Thanks in advance
Do they got a red ! Behind it ?
When you do a manual search
Sonarr doesn’t search for missing episodes automatically, so it can’t be checking too early; this is explained in the ((FAQ)).
There are a number of reasons why a release wouldn’t be grabbed though, especially if they aren’t monitored, but @TRaSH’s suggestion to check manual search should give you the easiest to digest display of that info.
