I have a number of series set up to download via torrents over vpn. All works as expected - the episodes download, are removed from qTorrent and then often just don’t import.
The reason is either because a) the download includes a non episode - (eg promo for the group that uploaded it) OR because there is a better version already on the system.
Once one episode ends up in this state no further episodes are automatically imported so I have to go do a manual import and then delete everything in downloads.
Is there a way to tell Sonarr to import valid files and just ignore the non-valid ones without stopping the whole process?
What is removing from qbittorent? If they are removes Sonarr won’t know they are there waiting to be imported.
As long as there is a video file Sonarr doesn’t care about the promos, etc, it will just ignore them. In the case of the better version Sonarr won’t import it, in that case the workaround is to remove it from the download client or change the category (label) in the download client.
One episode not being able to import won’t prevent another download from importing, sounds like something else is the matter.
We’ll need to see ((debug logs)) that show the issue importing to troubleshoot this.
I have enabled logs so will wait for it to get clogged again.
Previously Sonarr was ignoring anything if it was still seeding and I had no limit. I set the seeding limit in qTorrent and then Sonarr would import once seeding was complete.
One thing I have noticed was that when I go to Wanted > Manual Import and then select my directory, Automatic Import just doesn’t do anything if any of these sample files are in there. I have to go through and select the episodes I want to import by hand.
17-5-18 01:32:18.6|Debug|FetchAndParseRssService|Found 100 reports
17-5-18 01:32:18.6|Info|DownloadDecisionMaker|Processing 100 releases
17-5-18 01:32:18.6|Debug|Parser|Parsing string ‘The.Goldbergs.2013.S04E24.720p.HDTV.x264-AVS[rartv]’
17-5-18 01:32:18.6|Debug|Parser|Episode Parsed. The Goldbergs 2013 - S04E24
17-5-18 01:32:18.6|Debug|Parser|Language parsed: English
17-5-18 01:32:18.7|Debug|QualityParser|Trying to parse quality for The.Goldbergs.2013.S04E24.720p.HDTV.x264-AVS[rartv]
17-5-18 01:32:18.7|Debug|Parser|Quality parsed: HDTV-720p v1
17-5-18 01:32:18.7|Debug|Parser|Release Group parsed: AVS
17-5-18 01:32:18.7|Debug|AcceptableSizeSpecification|Beginning size check for: The.Goldbergs.2013.S04E24.720p.HDTV.x264-AVS[rartv]
17-5-18 01:32:18.7|Debug|AcceptableSizeSpecification|Possible double episode, doubling allowed size.
17-5-18 01:32:18.7|Debug|AcceptableSizeSpecification|Item: The.Goldbergs.2013.S04E24.720p.HDTV.x264-AVS[rartv], meets size constraints.
17-5-18 01:32:18.7|Debug|LanguageSpecification|Checking if report meets language requirements. English
17-5-18 01:32:18.7|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: The.Goldbergs.2013.S04E24.720p.HDTV.x264-AVS[rartv]
17-5-18 01:32:18.7|Debug|ReleaseRestrictionsSpecification|[The.Goldbergs.2013.S04E24.720p.HDTV.x264-AVS[rartv]] No restrictions apply, allowing
17-5-18 01:32:18.7|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. HDTV-720p v1
17-5-18 01:32:18.7|Debug|MinimumAgeSpecification|Not checking minimum age requirement for non-usenet report
17-5-18 01:32:18.8|Debug|RetentionSpecification|Not checking retention requirement for non-usenet report
17-5-18 01:32:18.8|Debug|DelaySpecification|Profile does not require a waiting period before download for Torrent.
17-5-18 01:32:18.8|Debug|HistorySpecification|Performing history status check on report
17-5-18 01:32:18.8|Debug|HistorySpecification|Checking current status of episode [3095] in history
17-5-18 01:32:18.8|Debug|DownloadDecisionMaker|Release accepted
17-5-18 01:32:18.8|Debug|Parser|Parsing string ‘The.Goldbergs.2013.S04E24.HDTV.x264-SVA[rartv]’
17-5-18 01:32:18.8|Debug|Parser|Episode Parsed. The Goldbergs 2013 - S04E24
17-5-18 01:32:18.8|Debug|Parser|Language parsed: English
17-5-18 01:32:18.8|Debug|QualityParser|Trying to parse quality for The.Goldbergs.2013.S04E24.HDTV.x264-SVA[rartv]
17-5-18 01:32:18.8|Debug|Parser|Quality parsed: SDTV v1
17-5-18 01:32:18.8|Debug|Parser|Release Group parsed: SVA
17-5-18 01:32:18.8|Debug|AcceptableSizeSpecification|Beginning size check for: The.Goldbergs.2013.S04E24.HDTV.x264-SVA[rartv]
17-5-18 01:32:18.8|Debug|AcceptableSizeSpecification|Possible double episode, doubling allowed size.
17-5-18 01:32:18.8|Debug|AcceptableSizeSpecification|Item: The.Goldbergs.2013.S04E24.HDTV.x264-SVA[rartv], meets size constraints.
17-5-18 01:32:18.9|Debug|LanguageSpecification|Checking if report meets language requirements. English
17-5-18 01:32:18.9|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: The.Goldbergs.2013.S04E24.HDTV.x264-SVA[rartv]
17-5-18 01:32:18.9|Debug|ReleaseRestrictionsSpecification|[The.Goldbergs.2013.S04E24.HDTV.x264-SVA[rartv]] No restrictions apply, allowing
17-5-18 01:32:18.9|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. SDTV v1
17-5-18 01:32:18.9|Debug|QualityAllowedByProfileSpecification|Quality SDTV v1 rejected by Series’ quality profile
17-5-18 01:32:18.9|Debug|MinimumAgeSpecification|Not checking minimum age requirement for non-usenet report
17-5-18 01:32:18.9|Debug|RetentionSpecification|Not checking retention requirement for non-usenet report
17-5-18 01:32:18.9|Debug|DelaySpecification|Profile does not require a waiting period before download for Torrent.
17-5-18 01:32:18.9|Debug|HistorySpecification|Performing history status check on report
17-5-18 01:32:18.9|Debug|HistorySpecification|Checking current status of episode [3095] in history
17-5-18 01:32:18.9|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] SDTV is not wanted in profile
Currently The Goldbergs and Fargo are both missing - they’re visible in the downloads folder but because of the two flagged items above I can’t do an automatic import.
The logs show the Goldbergs released being processed (but not grabbed) and no attempt to import it.
Do the releases show in Sonarr’s activity?
Do you still have Qbit removing downloads when they complete? If so, disable that, that will cause Sonarr to never import the download because it is treated as downloaded from the queue. Sonarr tracks downloads in the download client to know what is downloading, what needs to be imported and what has finished seeding (for removal when Remove Completed Downloads is enabled.
