Sonarr version: 4.0.5.1710
Package Version:4.0.5.1710-ls241 by linuxserver.io
OS: on Kubernetes
I’m experiencing an unexplained behaviour
The new episode is downloaded successfully but file importing in the storage folder is failing. Sonarr imports only 300-400Mb from 1Gb file and auto-restarts without any error message. In next import attempts it says “Destination already exists.” and restarts again or deletes the partial file and tries again… a chain of failures.
The import process is failing in Sonarr and Radarr, Both app containers were upgraded to the latest version. Kubernetes was upgraded to v1.30*. Everything was working fine a month ago or so…
And I’m wondering where the issue is:
- in the infrastructure: NAS drives, kubernetes, kubernetes workers or permissions?
- in Sonarr configuration?
Do you have any ideas why the episode file is imported partially and the container restarts automatically?
How can I get the actual error message?
When I copy the file manually and scan the series, everything works as expected.
The Info, debug and trace logs are normal. As I can see the Sonarr restarts at 05:18:11. Please check part of the logs below:
Info log:
2024-06-12 05:14:53.2|Info|RssSyncService|Starting RSS Sync
2024-06-12 05:14:56.0|Info|DownloadDecisionMaker|Processing 20 releases
2024-06-12 05:14:56.4|Info|DownloadService|Report sent to {my Torrent}. Indexer {my indexer}. {file name}
2024-06-12 05:14:58.0|Info|RssSyncService|RSS Sync Completed. Reports found: 20, Reports grabbed: 1
2024-06-12 05:18:11.8|Info|Bootstrap|Starting Sonarr - /app/sonarr/bin/Sonarr - Version 4.0.5.1710
2024-06-12 05:18:12.1|Info|AppFolderInfo|Data directory is being overridden to [/config]
2024-06-12 05:18:13.7|Info|MigrationController|*** Migrating data source=/config/sonarr.db;cache size=-20000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3;busytimeout=100 ***
Debug log:
2024-06-12 05:17:56.6|Debug|ImportDecisionMaker|File accepted
2024-06-12 05:17:56.7|Debug|EpisodeFileMovingService|Copying episode file: /data/{file name} to /films/Series/{file name}
2024-06-12 05:17:56.7|Debug|DiskTransferService|Copy [/data/{file name}] > [/films/Series/(file name)]
2024-06-12 05:18:13.7|Debug|ProcessProvider|Found 0 processes with the name: Sonarr.Console
2024-06-12 05:18:13.7|Debug|ProcessProvider|Found 1 processes with the name: Sonarr
2024-06-12 05:18:13.7|Debug|ProcessProvider| - [145] Sonarr
