Hi guys,
First, thank you for the great work!
I am running Sonarr on Synology. Everything works fine except it constantly throws errors in logs. Please see below. How can I fix it?
EPIC FAIL: libgdiplus.so: libgdiplus.so
System.DllNotFoundException: libgdiplus.so
at (wrapper managed-to-native) System.Drawing.GDIPlus:GdiplusStartup (ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus…cctor () [0x00000] in :0
EPIC FAIL: An exception was thrown by the type initializer for System.Drawing.GDIPlus: An exception was thrown by the type initializer for System.Drawing.GDIPlus
System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.GDIPlus —> System.DllNotFoundException: libgdiplus.so
at System.Drawing.Image.InitFromStream (System.IO.Stream stream) [0x00000] in :0
at System.Drawing.Bitmap…ctor (System.IO.Stream stream, Boolean useIcm) [0x00000] in :0
at (wrapper remoting-invoke-with-check) System.Drawing.Bitmap:.ctor (System.IO.Stream,bool)
at ImageResizer.ImageBuilder.DecodeStream (System.IO.Stream s, ImageResizer.ResizeSettings settings, System.String optionalPath) [0x00000] in :0
at ImageResizer.ImageBuilder.LoadImage (System.Object source, ImageResizer.ResizeSettings settings, Boolean restoreStreamPos) [0x00000] in :0
