Sonarr version (exact version): Docker linuxserver/sonarr:3.0.10
Mono version (if Sonarr is not running on Windows): Docker linuxserver/sonarr:3.0.10
OS: Debian 12 // Docker linuxserver/sonarr:3.0.10
2023-07-07 10:57:03.2|Warn|ArgumentValidator|The string can't be left empty, null or consist of only whitespaces.
2023-07-07 10:57:03.2|Error|DownloadDecisionMaker|Couldn't evaluate decision on The.Walking.Dead.Dead.City.S01E01.PROPER.VOSTFR.1080p.10bit.WEBRip.6CH.x265.HEVC-FERVEX
[v3.0.10.1567] System.ArgumentException: The string can't be left empty, null or consist of only whitespaces.
Parameter name: key
at NzbDrone.Common.EnsureThat.EnsureStringExtensions.IsNotNullOrWhiteSpace (NzbDrone.Common.EnsureThat.Param`1[T] param) [0x0001e] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\EnsureThat\EnsureStringExtensions.cs:18
at NzbDrone.Common.Cache.Cached`1[T].Get (System.String key, System.Func`1[TResult] function, System.Nullable`1[T] lifeTime) [0x0000d] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Cache\Cached.cs:89
at NzbDrone.Core.Profiles.Releases.TermMatcherService.GetMatcher (System.String term) [0x00014] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Profiles\Releases\TermMatcherService.cs:35
at NzbDrone.Core.Profiles.Releases.TermMatcherService.IsMatch (System.String term, System.String value) [0x00000] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Profiles\Releases\TermMatcherService.cs:25
at NzbDrone.Core.DecisionEngine.Specifications.ReleaseRestrictionsSpecification+<>c__DisplayClass9_0.<ContainsAny>b__0 (System.String t) [0x00000] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\DecisionEngine\Specifications\ReleaseRestrictionsSpecification.cs:70
at System.Linq.Enumerable+WhereListIterator`1[TSource].ToList () [0x00017] in <f6c405b973804b5c804e7e759353765f>:0
at System.Linq.Enumerable.ToList[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x0001f] in <f6c405b973804b5c804e7e759353765f>:0
at NzbDrone.Core.DecisionEngine.Specifications.ReleaseRestrictionsSpecification.ContainsAny (System.Collections.Generic.List`1[T] terms, System.String title) [0x00014] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\DecisionEngine\Specifications\ReleaseRestrictionsSpecification.cs:70
at NzbDrone.Core.DecisionEngine.Specifications.ReleaseRestrictionsSpecification.IsSatisfiedBy (NzbDrone.Core.Parser.Model.RemoteEpisode subject, NzbDrone.Core.IndexerSearch.Definitions.SearchCriteriaBase searchCriteria) [0x000a7] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\DecisionEngine\Specifications\ReleaseRestrictionsSpecification.cs:42
at NzbDrone.Core.DecisionEngine.DownloadDecisionMaker.EvaluateSpec (NzbDrone.Core.DecisionEngine.Specifications.IDecisionEngineSpecification spec, NzbDrone.Core.Parser.Model.RemoteEpisode remoteEpisode, NzbDrone.Core.IndexerSearch.Definitions.SearchCriteriaBase searchCriteriaBase) [0x00000] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\DecisionEngine\DownloadDecisionMaker.cs:187
2023-07-07 10:57:03.2|Error|DownloadDecisionMaker|Couldn't evaluate decision on The.Walking.Dead.Dead.City.S01E01.FRENCH.1080p.WEB.x264-FW
Parameter name: key
Hello !
I have this error when I want to download an episode of any series. I don’t understand what’s the problem and I can’t find someone with the same issue than me (ReleaseRestrictionsSpecification)
Here’s what I see on Sonarr when I start a search manually
If someone could help me, thanks a lot =)
