Sonarr version (exact version): Mono version (if Sonarr is not running on Windows): OS: LibreELEC ((Debug logs)): (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here) Description of issue:
I’m new to using Sonarr. Been using a version of Automatic on my HTPC before, with a RSS feed and RegExp config file.
My Transmission is configured to not use a incomplete folder, and the torrent is added to the correct path for the specific TV show direct, with a .part file ending in the name. I like that Automatic could start the download in the correct path direct.
But now when checking the logs for Sonarr, I understand that Sonarr first download the episode to the default download path in Transmission, and then later use a “move function”.
Sonarr will only move torrents that have finished seeding, otherwise it will copy or hardlink it into the series folder (depending on your settings and whether the download directory and series folder are on the same volume). Sonarr doesn’t support downloading directly to the series folder at this time.
