Download Clients Fail After Reverse Proxy Turned On
V: 3.0.10.1567
OS: DSM 7
Logs: gist
I had begun making changes on DSM like getting to the point where I set up a website and a reverse proxy. While I did all of this, somehow, my Sonarr & Radarr both stopped communicating with my download clients. So what’s a man to do? Well I decided to recreate everything. Literally everything. I remade my Sonarr, SABnzbd, Transmission. Nothing has worked. I’ve downgraded my security. Turned on / off my firewall. Removed ALL changes to my DDNS, deleted my reverse proxy. Same error for everything, nothing will connect. So let’s just see about what my terminal says:
i ran this:
curl http://192.168.2.5:8080/api?mode=get_config&apikey=2272ead825af4fb7bf0494a4bbb7a28b&output=json
output:
[1] 28548
[2] 28549
So It returns processes, which I’m just not sure exactly what’s happening. Sonarr says:
Test was aborted due to an error: Unable to connect to SABnzbd, The operation has timed out.: 'http://192.168.X.X:8080/api?mode=get_config&apikey=XXXXXXXXXXXXXXXXXXXXXX&output=json'
