I am currently using BTN. All the other single episode - single file downloads are working. However there is one combined episode which is not showing up in even manual downloads. What should I do?
You’ll need to grab it manually, set the proper category/label in the download client and let Sonarr import it.
The issue is BTN isn’t returning the result via search, but Sonarr should be able to process it fine.
Nice, that worked perfectly.
