OS: Synology NAS 1815+ - DSM 6.2.2-24922 Update 4
Debug logs: https://controlc.com/a4a25d88
I had a complete setup between SABnzbd, Sonarr and Radarr running as an application on DSM. It all worked well. Then i decided to move all three services into Docker. I’m new to Docker but i like the flexibility and frequency of services updates. But since moving all three services across, I’ve run into permission issues. I’ll concentrate on SABnzbd and Sonnarr…
SETUP
SABnzbd runs as a Docker container with the following setup;
Sonarr runs as a Docker container with the following setup;
The PGID and PUID is correct. All three services are utilising an admin account that’s a part of the Administrators Group. The folders locations are as following and are all assigned with RW permissions.
SABnzbd see’s the Downloads location and files. It downloads to them no problem.
Sonarr also can see the Downloads location and TV Shows folder, which means i have mapped them correctly when setting up the Docker container. But for some strange reason, it cannot import ANY files…this is the error message that continues to appear;
Can someone please tell me where I’ve gone wrong with this setup? the PUID user has all the correct permissions assigned to all the folders, I just can’t seem to work this out…
