Sonarr version (exact version): linuxserver/sonarr:latest Mono version (if Sonarr is not running on Windows): Not sure in the docker file OS: Ubuntu 20.04 Debug logs: Description of issue: I use docker compose to start my batch of containers. And got a bit tired of FDH in SickRage not working, so I wanted to give Sonarr a go. But it never starts, and I can’t connect. Radarr works fine. but I’ve noticed in my search for an answer to why it dosen’t start that the image name for radarr (and sickrage) just is a hash value. See docker -ps : https://pastebin.com/fmWSdYwG
What am I missing?
When I go to Portainer, it don’t show any published ports either. So I assumed that something is going wrong. a docker-compose ps gives me the following:
** Name Command State Ports ** -----------------------------------------------------------------------------------------------------------------------------
**docker_sonarr_run_aedd9c4da8ee /init Up 8989/tcp **
**radarr /init Up 0.0.0.0:7878->7878/tcp **
It states that it’s up, and the ports are open, but it doesn’t state for whom. 0.0.0.0 i assume is any, but for some reason Sonarr don’t get that. How do I specify which IP’s can connect?**
Secondly, the name bugs me. Why don’t it follow the name I gave it in the compose file?
