OS: OMV 6 (docker)
Debug logs: Log files after enabling debug and trying to log in locally:
2023-10-21 11:32:28.6|Debug|Api|[PUT] /api/v3/config/host: 202.Accepted (151 ms)
2023-10-21 11:32:28.6|Debug|Api|[GET] /api/v3/health: 200.OK (1 ms)
2023-10-21 11:32:29.1|Debug|Api|[GET] /api/v3/health: 200.OK (1 ms)
2023-10-21 11:32:46.6|Debug|Api|[GET] /api/v3/command: 200.OK (1 ms)
2023-10-21 11:32:46.7|Debug|Api|[GET] /api/v3/command: 200.OK (1 ms)
2023-10-21 11:32:55.1|Debug|Api|[GET] /api/v3/health: 200.OK (1 ms)
2023-10-21 11:32:55.2|Debug|Api|[GET] /api/v3/system/status: 200.OK (33 ms)
2023-10-21 11:32:55.2|Debug|Api|[GET] /api/v3/diskspace: 200.OK (100 ms)
2023-10-21 11:32:56.3|Debug|Api|[GET] /api/v3/log/file: 200.OK (28 ms)
2023-10-21 11:34:16.6|Debug|Api|[GET] /api/v3/command: 200.OK (1 ms)
Description of issue : When the login configuration is set for “Disabled for Local Addresses”, it doesn`t work, i keep getting the login page every time i enter Sonarr on my local network from a web browser. I have restarted and cleared my caches.
