Sonarr version (exact version): 4.0.9.2244
OS: Windows 11 Home
Debug logs: Ask
Description of issue: Can’t upgrade to file with higher CF score (automatically) because CF score is different when grabbing (higher) and importing (lower). See Images attached.
I’m not sure if I’m doing something wrong with Custom Formats or Media Management. For some reason, releases are being grabbed correctly (see Image 1) but are not being imported automatically because the CF score when importing the grabbed file is lower than when grabbed (see Image 2).
I know the main issue for this is my “DUAL-AUDIO” CF, but I’m not sure what’s causing the problem. The DUAL-AUDIO CF is missing when I try to manually import (see Image 2). What’s weird is this is only happening when importing and if I manually import, the CF score working properly (see Image 3).
I’m pretty sure my CF is applied correctly and I’ve attached the relevant images below.
See Image 7 for the episode I’m trying to update.
See images below for Media Management settings.
Please let me know if any other details are needed.
