Detecting hardcoded letterboxing possible?
Sonarr version (exact version): 4.0.14.2938
OS: truenas scale
Some of the series that come in ultrawide end up being hard letterboxed to fit 16:9 displays with no indication in the filenames. Watching the video on an ultrawide monitor also adds in pillarboxing and the video will be a strip with a thick black border. Some series I haven’t found releases without the letterboxing even after 3 or 4 tries, and not everything even has that many.
Is there a solution/workaround that already exists, or do some studios actually hardcode letterboxes in their streaming and bluray releases?
Edit: So one of my friends does his own rips and told me that it is usually the difference of actually ripping the disc or downloading the media files from the streaming service vs intercepting the hdmi and recording that to a file. I don’t know if there is a givaway for bluray source but for streaming he told me to grab web-dl instead of webrip and so far that does it.
I did some testing in case anyone else is crazy enough to use an ultrawide monitor for movies. It seems like the bars are indeed part of the blurays after ripping a few myself. They can be removed when reencoding but I couldn’t do it without worsening the image and/or making the file bigger than it originally was. The alternative I am using is to use mkvtoolnix header editor, expand video track, then in both video crop top and video crop bottom check add element and set to 276. This worked in mpv and also jellyfin so I assume at least any mpv based player will respect the setting.
