Is there any way to index other sites, that use xml/rss 1.0/2.0? Especially demonoid…
Thanks
Thanks
Not at the moment, but it will be coming in a future version.
I see RSS is now available. I’m trying to use http://www.demonoid.pw/rss/0.xml
Each cookie value I try results in the error “Unable to connect to indexer. See log for details” Since login isn’t required to see the rss, I also tried without a cookie value. That results in the error “Indexer feed is not supported: Feed doesn’t contain the release content size.” However you can see a “Size” for each entry in the xml. What is required for sonarr to recognize size labels within xml?
EDIT: I also tested the rss for TV only http://www.demonoid.pw/rss/3.xml and that connection was successful without a cookie although the format appears to be identical. Not sure how well it will be able to grab torrents, but I guess we’ll find out.
Might be something that can be done in Jackett?
Good suggestion, I’ve added a request for demonoid. We can likely get it added to Jackett soon.
https://github.com/zone117x/Jackett/issues/127
Demonoid has been implemented in Jackett and will be available next release.
