2.0.0.5085
OS:
Windows Server 2012 R2
It seems that when you use a proxy, and even though the proxy setting “Bypass Proxy for Local Addresses” is set to yes, the download client still attempts to use a proxy on a local address.
I figured this out because I am installing Deluge on a separate machine, instead of local host, and I am needing to connect to another local IP to use Deluge.
So, I have configured the Proxy settings to use Socks5 with PIA
I have tried I have setup the “Bypass Proxy for Local Addresses” to Yes and I have also tried to place the other server’s IP in the “Addresses for the proxy to ignore”, on where Deluge is installed.
If I attempt to setup my download client, it fails with Unable to test connection: The underlying connection was closed: The connection was closed unexpectedly.
If I disable the Proxy, by changing Use Proxy = No, and then attempt to connect to Deluge, it works perfectly as expected.
Does the download client configuration not adhere to the bypass proxy for local addresses option?
FYI. Sonarr is at IP 192.168.1.252 and the Deluge install is at IP 192.168.1.248. Both servers have the same gateway address, 192.168.1.1
Is there any way possible to have the download client adhere to the bypass proxy for local addresses option? I would love to keep my Proxy up and running and also have Deluge on a separate machine.
Thanks and thank you so much for this software, you guys are the bomb!!
