Version 3.0.9.1549
Package Version 3.0.9.1549-ls162 by linuxserver.io
Mono Version 6.12.0.182
2022-11-02 07:08:03.1|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: /data/complete/Andor.S01E09.Nobodys.Listening.1080p.DSNP.WEBRip.DDP5.1.x264-NTb[rarbg]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
Ok so Sonarr. tells deluge to download a file. This is working.
Deluge then moves the directory that it just downloaded to /data/complete/. So far so good.
The problem seems to be that sonarr is looking for the actual file, and not the directory.
As you can see in the logs, there is no / after the path where sonarr is looking, so of course, it can’t find anything.
This gets us stuck in a situation where the file is downloaded, but sonarr can not import because it can not find it. It won’t look into the directory where the file is.
Has anyone else had this issue?
Fixes?
Thank you,
