Yeah, thats the one.
Ok. It was already enabled.
Anyway, I’ve noticed that some files get deleted, others do not.
And it looks like, usually, all of them are moved to the tvshows folder.
The ones that are not moved are the ones in “Queue” after the download is finished in Deluge.
There are hundreds of logs. I really can’t understand what the problem is.
But I found out that now there is another issue. Sonarr crashes very often, and I have to restart the computer in order to make it work.
I still don’t understand the issue, but you can look in the logs for the release from Deluge (use the path or name).
Open a new thread about the crashes please, with the relevant details (OS, version of mono/Sonarr, etc) and the end of the logs before the crash.
