Sonarr version (exact version): 2.0.0.5163 Mono version (if Sonarr is not running on Windows): 5.8.0.108 OS: Synology DSM 6.1.6-15266 Update 1 Debug logs: Not yet enabled Description of issue:
Hello,
i have Delay Torrent set to 2200 minutes (~36 hours), and i am using torrent only.
It works fine for all my TV shows, however it doesn’t work for Anime only (series type = Anime).
It’s problematic because usually lower quality versions (720p) are posted before higher quality (1080p), and i end up getting 2 downloads for the same episode.
Using Delay Torrent is usually sufficient to avoid that for TV shows.
It seems the age shown is not correct compared to the original torrent.
This particular indexer is used via Jackett, and after checking other indexers i have (via Jackett or not), it seems to be the only one where the age/date is incorrect.
