Sonarr version (exact version): 2.0.0.5085
Mono version (if Sonarr is not running on Windows): 5.2.0
OS: FreeNAS 11.1
I’m looking for a way to get rid of the -xpost / -postbot in the names of releases downloaded from usenet.
Here is a sample.
18-2-8 11:06:41.8|Info|Sabnzbd|Adding report [Violet.Evergarden.S01E03.1080p.WEB.x264.1-MEMENTO-xpost] to the queue.
The file is then renamed per my rules to:
[xpost] Violet.Evergarden.S01E03.003.May.You.Be.an.Exemplary.Auto.Memoir.Doll.WEBDL-1080p.x264.EAC3 instead of
[MEMENTO] Violet.Evergarden.S01E03.003.May.You.Be.an.Exemplary.Auto.Memoir.Doll.WEBDL-1080p.x264.EAC3
The easiest way is to just exclude xpost released via a “must not contain” rule but there are times when the original fails to download due to missing / bad blocks and the -xpost release works. Is there another quick fix to remedy this issue?
Would I want to create a post processing script in sabnzbd or for sonarr?
Thanks in advance
