Hi. Lovin’ Drone.
But one thing that would make it even better, would be the ability to STOP downloading an episode in higher quality, if it’s already been seen in XBMC in lower quality than your cutoff in NZBDrone.
I have a add-on (FileCleaner) in XBMC that deletes episodes automaticly after 3 days after I’ve seen them. And it’s a pain when Drone replaces episodes in my Series folder, and they are marked “Unwatched” in XBMC (so the plugin does nothing).
I mean, you can make Drone tell XBMC when an episode is downloaded, can’t you make XBMC tell Drone when an episode is watched? And then NOT download it again (in higher quality).
Oh, and this would also benefit those with a bandwith-limit.
Hope I made my point clear and it’s understandable. Thanks for any consideration
Or should I post this in the XBMC forum?
- donkeyhigh
