The WIKI for custom processing or API calls doesn’t have much information on the Python syntaxes. Also, on the forum most topics are about curl or bash.
So I thought, let’s share the scripts I made as a reference. It contains the following functions that might help you get a grasp of the basic python syntax for the following functions:
Custom Post-processing Scripts (https://github.com/Sonarr/Sonarr/wiki/Custom-Post-Processing-Scripts)
- Extract subtitles with FFMPEG --> https://pastebin.com/FUUrcWf2
- Convert the Sonarr environment variables to a python variable
API (https://github.com/Sonarr/Sonarr/wiki/API)
- Trigger a rescanSeries on a second Sonarr instance --> https://pastebin.com/Yi7Bz2ji
- Perform a JSON get and parse it to a python variable
- Perform a JSON post to trigger an command
Hope this helps in reducing the tinkering time if you want to play around with it.
