Is there a way to set an index preference for a single series? I find that the files pulled from NZBGeek for a particular show tend to be really jittery, but that the ones I get from GingaDADDY work well. Can I set up preferences for a single series to prefer GingaDADDY…or simply only choose it?
Thanks!
Micah
The only way you could achieve this is if there is a common word in the NZBGeek releases (I know they re-up with their own tag on the end) and use release restrictions tied to a tag to block it and add that same tag to the series.
There isn’t a way to strictly use an indexer/not use an indexer for one series.
