Sonarr version (exact version): Mono version (if Sonarr is not running on Windows): OS: Debug logs: (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here. Post in .txt not .doc, .rtf or some other formatted document) Description of issue:
The sonarr devs don’t make/maintain a syno package as far as I know.
Synocommunity has one, but they only have v2 it seems: https://synocommunity.com/package/nzbdrone
If your syno supports docker that is another route to go.
same, i limit the ram it can access to 1gb but it tends to sit around 300mb. cpu typically only spikes during the 1/2 daily rescan process and is normally at 2-5% (dual core 1.8ghz atom)
plus i like being able to update the image without worrying about what mono package will work/break anything else.
