Content Certification Display Missing
Sonarr version (exact version): 4.0.15.2941
Mono version (if Sonarr is not running on Windows): 6.0.13
OS: Docker on Ubuntu Server
Description of issue: Certification Not showing up in show details
I’m curious how to get the content certification (TV-MA, TV-Y, etc…) to show up in the show’s UI. Maybe I’m just missing it, but I’m able to create a filter based on the value. (Filter->Custom Filter->Certification) but I can’t see anywhere on the show detail screen what the certification rating is, even for the shows that are filtering correctly. Did I miss a setting that enables the display? I expected it to show up in the second row of show info with the year and such like it does for radarr.
FWIW, I tried searching for an answer but as you can guess, all “certificate” results are about https issues.
Thanks
AFAIK the only place that the certifcation rating is even viewable is in Table view mode and you have to enable the column.
