**Sonarr version 2.0.0.4753 **:
Windows 10 Pro x64 Creators Update:
Debug Log
I cannot get Sonarr to connect to QBittorrent. I previously had Deluge setup just fine, but for various reasons I need to migrate to QBittorrent. I have just reinstalled QBitorrent on the same computer I have Sonarr installed on and the only settings I changed in QBittorrent where to enable the web GUI and set the authentication for it. I set the web GUI username as admin and the password as password and left the port on 8080 for testing purposes. I can browse to localhost:8080 and login to QBittorrent just fine though Chrome, but it will not work in Sonarr. I have double checked that I have put the correct settings in Sonarr, see attached screenshot, but it refuses to connect. I am also not using SSL.
I also have similar issues in Radarr, I can post those debug logs as well if it will help.
Can anyone please help?
